IIRC in the 2012 Scenic (phase 2) they ended mid-way, about 60 degrees.Service position, wipers are virtually touching the Sides of the windscreen as in straight up..
So OP, don't panic
Can I pick your brain on this too.Service position, wipers are virtually touching the Sides of the windscreen as in straight up..
The multi plugs are the plugs that go on the motors, but wiper arm and the piece of plastic covering the wiper arms need to be taken off
Hi , I have a same problem with my wipers (scenic3) it's driving me nuts , can you please help ? I.did not understand properly how to initialize the wipers to work properly? Your help is much appreciated.Ok guys sorry for late reply I was working away and only just got around to doing the procedure that ours2012 sent me, I can report back now that all is well and the procedure was spot on both wipers now working..
thanks for you help guys Flack :smile2:
Have you tried the initialisation procedure?Hi can someone help please I have a renault grand scenic 2010 m1, my window wipers stopped working last week but then worked again, now stopped altogether again the passenger one sometimes works but the drivers doesn't at all,
1.does anyone know where the fuses are
2.does anyone know where the relay is
3.ive done the inialize thing but not worked
4. Should I just buy new motors
Please someone help?
If that hasn't worked then it is down to replacing wiper motors, did you have a look at the other wiper threads with the repair options?Yes I've done that
Excuse me for being thick but everyone goes on about the " multi plug', where abouts is this?Have you tried following Stuart's instructions?
To initialise wiper motor, with ignition on, turn wiper stalk from 0 to 1 then 1 to 0, turn ignition off,,,
Now disconnect multi plug .....
Dont put the wiper arms on, as your initial settings will be different.
Reconnect your multiplug .
Now turn ignition on, and pull the stalk down, this will put the wiper motor in service position ( where you put it to change the blades) , in this position, now put your wiper arm on,.
Once done,, put switch into off position, wipers will return to normal position...
See if that sorts it...
Hi mate, did you ever find out where the multi plug is? I’m thinking the very same thing!Excuse me for being thick but everyone goes on about the " multi plug', where abouts is this?
What and where is the multi plugTo initialise wiper motor, with ignition on, turn wiper stalk from 0 to 1 then 1 to 0, turn ignition off,,,
The multi plug = the plug that goes on the wiper motor
