Hi, I have a grand scenic mk4 and the left headlight has a crack, this allowed water in and caused the LED headlight to stop working, these Xenon headlight cannot be replaced so Instead I had to replace the whole unit, Renault wanted 1k, git one fro 300 quid. But the light still does not work.
The Indicator is separate therefore that works
I’m hoping the fault is due to a blown fuse however I can’t find the fuse for the headlight.
the manual says it is in the fuse box how we I don’t have one, Im just wondering does anyone have an image of the layout as I can’t find it anywhere online.
Otherwise it’ll be a trip to Renault for me :(
Grand Scenic 1.6 2007
Don't know exactly on the GS4 but the earlier versions had one in the back of the glovebox and another behind the battery tucked up under the wipers.
Thanks for that Info, however no luck, I can’t find the layout anywhere. Also the fuse box on the 2017 grand scenic is hardly accessible. Covered by large amounts of plastic from the glovebox
178788
