Hi All,
Apologies I posted this thread under the wrong forum earlier.
Just wondering if anyone can offer any advise/assistance on a problem I'm having with the Air conditioning system on our 54 plate Grand Scenic.
When the air conditioner is switched on - light comes on but compressor does not kick in and no cold air. I have checked the fuse and its ok. This is the second time in a year that it has failed. Last time it was re-gassed and the pressure switched changed at our local Renault dealer, plus it needed a diagnostic check.
Recently the blower stopped working on settings 2&3 but has since corrected itself and started working on all settings again. Having read the forum posts, last night I went behind the Dashboard and found that the plug and the blower resistor pack had burnt slightly, so it looks as though these parts will need renewing soon.
I was just wondering if anyone knew if this blower problem would log a fault code to the ECU which would disable the Air conditioning?
I have heard that the A/C is disabled under certain fault conditions & needs to be switched back on using the Renault CLIP diagnostic tool/software. Is this correct?
If I changed out the resistor and wiring loom would the A/C fault reset itself or would I have to get Renault to do it?
I rang my local dealer to see if they could offer any technical assistance prior to me coming to them to get it sorted but they were less than useful and would not help - saying that they could only diagnose it if I paid for a diagnostic check.
As its the second time is happened quite recently, I'm reluctant to waste money at my un-helpful dealership if its something I can sort out myself.
Bren Shipley
Bren Shipley
