1 - 9 of 9 Posts
Hello,
I am totally new to the forum and hoping someone can help me.
I have a Grand Scenic MK3 2011 and the rear fog has stopped working including the little light on the dashboard. I have checked the bulb which is good. I have also checked the connection with a multimeter. Can anyone help on where to go next.
Thankyou in advance
Rob
Obvious questions first. It has worked in the past?? Has there been a tow bar fitted?? Headlights on when checking?? Front fogs fitted?? And working??
It has worked in the past, there is a towbar fitted which was already on the vehicle, all the lights were on and working, it was only picked up this afternoon as it failed the MOT on the rear fog's not working
The fog light was working, and the tow bar was already fitted. The lights were all checked on the MOT which highlighted the rear fog problem.
kind regards
Rob
Check the Cr4ppy switch in the black tow socket. Euro rools insist Car fogs extinguish when caravan plugged in.
1 - 9 of 9 Posts
