Yes !
Make sure you tell the tyre fitters that you have tyre sensors, if you don't they might just rip the valves out and ruin the sensors as they do with normal valves.
Once the new tyres are fitted and back on the car the sensors should work as they did before the tyre change as long as the wheels are put back on the same corners that they came off as they are coded to that position.
