I am new on here so Hi to everyone :eek:
I have a new shape (Dec 2003) Grande Espace with one of those panoramic full length sunroofs - However there seems to be a plasticy kind of rattle coming from the front of the roof when the sunroof is closed (Above or near the lighting console or sun visors)!!!!!!!.
Just wondering if anyone else has experienced a similar problem - If so any suggestions on a cure would be greatly aprreciated.
Thanks in advance.
J :)
Just a thought I wonder if it is the wind deflector or something in that area. I don't know how you could test or eliminate whether it is this. Maybe you could check if anything seems loose when the sunroof is open.
Hi NS
Had a look at the wind deflector and all is OK - The noise seems to be coming from under the big plastic cover at the front which houses the motor etc and I haven't got a clue how to remove it :eek: :eek:
Thanks.
Hi SV,
Nor do I - hopefully someone out there will be able to give some clues or advice - strnage that it is only when it is shut.
Hope you can get it sorted.
NS
