Random Visitor
ive got a slight grinding noise at the front in slow speeds, apparantly in the last mot it turned up i had a slightly pitted brake disc, would this cause the noise??
Hi iam not that sure it may be time for front disc change or is there alot of wear on the pads as well as the discs. When where thay last changed.If the lad from the mot testing centre told you they were pitted iam sure as time has gone on they will not have got any better i hope this helps Donald.
hi it could be possible if the pitting is heavy enough, sounds more like the start of the pads wearing down and catching the edge of the disc,
sound advise given change the front pads and discs
goodluck
bigshow
