Hi there new to the forum sorry if this is the wrong area
Anyways I have looked for a ground point in my book and though the bolt for the rear seats was a good idea uniti I could not get them off.
What is the next best option if ? Is there a factory ground point or would I have to drill a whole in the boot ?
Cheers shaun
Ps 2003 renault Clio 1.2 5dr
What do you mean exactly? All speakers have two wires which go to either a head unit or seperate amplifier. SO YOU DO NOT BOLT THEM TO THE CAR CHASSIS.
Most sub-woofers have their own power supply so need both a voltage supply and a earth return.
Cheers shaun
The seat bolts can be very tight as they usually have thread lock compound on their threads but you should be able to find a suitable earth point around the rear light clusters.
Re: Ground point for subwoofer
Indeed, but one DOES bolt the Sub Amp down & supply a good local earth, as you know.
Shaun, you are right to find a good earth, as the car body has a MUCH lower resistance than any cable. If you can't find one in the boot, although there should be one for the rear lights & HRW, then make your own. Clean off the paint, two fat washers, nut & bolt & some grease to stop corrosion. Robert's yer fathers brother.
Don't forget to let the car "sleep" before disconnecting Battery if you have an EPB. DAMHIK?
Hi there cheers for the advice
How abouts would I go to access the ground point for the lights ?
Only know Scenics, on those the earth is behind one of the clusters. Sorry
Hi Shaun, to access the earth for the rear lights in your Clio you need to remove the black plastic trim across the base of the boot opening (where the boot lock is situated)
Once this is removed (x4 Torx screws) you will then see the black earth cable for the rear lights held to the body by a screw. There is one on each side of the car. Be careful when removing the screw, I snapped the head off one of mine!
