Not a lot to go on. Full car details please will help as well as a description of the problem and what led up to it. Scenic II has a different handbrake to Scenic III.
Hi thanks for replying. It***8217;s a scenic 2007 7 seater 2.0 petrol manual. The hand break is flashing red and service is on with a p in triangle. It will not go on . I tried the reset steps leave door open look doors put key in and press small button on hand break and start button I can hear the motor but still won***8217;t apply the parking break
On your car I think it is a cable (operated by motor). These cables can seize up or break. Since you can hear the motor I would suggest someone takes a close look at the rear (while jacked up, chocked and 100% secure). Before that, search this forum. There is a wealth of information here about Scenic II handbrake issues. It's repairable if you have the skills and inclination; otherwise it may need a trip to a local trusty mechanic.
