1 - 17 of 17 Posts
I just cant find one .... can someone link me to one to buy ?
Thanks in advance:grin2:
You Wont, They didn't cover the Facelift models for the Meg or the Scenic. :crying2:
Major differences are mainly plastic bits.
TBH, I've not found mine that much use. 1/2 the wiring diagrams I want aren't in & it keeps telling me I MUST disconnect the battery, to empty the Ashtrays. :smile2:
LOL wow .... maybe French translation ? :)
Thats a pity but i suppose thats why forums like this are about .... always someone to hold your hand.
While I have your attention i noted that there appears to be a slight oil drip coming from some kind of appendage under the car which i suspect to be the sump plug. Should i just nip it up ?
Wot no Undertray?
Perhaps a piccy would help?
We love piccy's
Maybe worth doing an oil change , with new seal on the drain plug :)
Yeah might be an idea but dont have much space out front .... and what there is its monobloc that we have just cleaned up .... the Mrs would string me up if i get anymore drips lol
Whats this models favourite tipple .... I might just give it a go anyway
Damn ..... new sump required do you reckon ?
Needs a good look, next time you change the oil.
I had a cracked one once, Big washer, scrupulous cleaning & industrial sealant, cured it.
First you need to know more about the damage.
Don't suppose they're cheap. :frown2:
Discussion Starter #12
Looks like a sump repair kit has been used, clean it up, tighten it up and see,,
Discussion Starter #15
Ahhhh I see what you mean. Wonder how bad it was; either its just a stripped plug ..... or is it something more ..... is that some weld or epoxy all around it.
Problem i have is speed bumps are all over this town and that thing fair stick out.
Discussion Starter #16
Possible, Need engine Code & Suffix I.E. K4M 812
The suffix changes with each engine improvement.
Found on a sticker on the Cambelt Cover.
Look how the sump plug varies from that abomination on yours.
Will check but even it is occured to me it might not be just a quick removal ..... is it a bugger removing these keeping in mind my lovey monobloc lol
1 - 17 of 17 Posts
