Hi can anyone help me with my hazard warning lights .My Indiacators are working ok but when I switch my hazards on they dont work. I have checked all the fuses but they are all ok. Any help would be appreciated. I have a 2003 facelift kangoo van. Thanks.
Hi there mate, I'm no electrician, but I would suspect (from what you've said) that the fault is with your hazard light switch - it may be a loose/bad connection or broken wire.
If it looks straightforward enough to remove, I'd be tempted to extract it (careful not to let the wires fall into the dash), and have a look around - it may even be something like juice being spilled over it.
Hope that helps,
Paul:)
Hazards
Hi just back in from checking switch, discovered I accidently pushed the plug off the back of the switch. When I removed the radio last week I slide the radio back in and it must have caught the plug and pushed it off.How thick is that,still thats it sorted Cheers
Very easily done. Glad that's it fixed.
All the best,
Paul:)
