Hi all i have a clio 2002 for some reason the hazard lights just come on by them selfs and the switch makes no diffrence at all i even disconnected the switch and they were still on disconnected the batt then reconnected thay were still going after a while they do switch off but could come back on at anytime and stay on for how ever long they want very strange anybody have any ideas thx great forum by the way.
Hello & Welcome to the Forums.
Hopefully a Member will be able to assist with your post who has more Technical knowledge than myself.
Ottoman
hi. clio 2 phase 2 have a very common problem with hazard switches. i have had to change no end of em for bein faulty. they are pretty cheap to buy iirc. easy to fit to. jus pull your radio out then disconnect switch and pop out and replace. if problem does persist though then there is a wiring fault somewhere and/or your uch will be playing up and for that u may need to go main dealer to be repaired
