Hi, I am having problems with the lights on my megane (2001 DTI), when I turn on the lights the dip beam comes on as normal, when I switch to high beam the light in the dash changes to high beam but nothing happens to the lights. I have checked all the fuses and they are OK. My friend has a 2000 megane and he also has the same problem. Has anyone else experience this and if so what was the cause. Thanks.
Start with the easy things first.:)
Check the bulbs,and if they are OK then ideally you need a multimeter or test light and see if you have any feed to the bulbs.The earlier Meganes had a tendency to lose the earths to the headlights,but I think the later ones are better.
Check the bulbs and for a feed,then get back to us.:)
