Headlights cutting out for no reason,but will come back on if i turn light switch off and back on again or flick switch to high beam and then back to dip.This has happened only once or twice, but i have no idea why it has started to do this all of a sudden.My car is a T,reg 99 scenic "any advice on what might be the problem would be appreciated.
Hello and welcome to the forum :)
If its the same setup as the Lag 1 (rotary light switch on the same stalk as the indicators) then it sounds very much like a faulty stalk to me.
It may be simply just a broken filament which can make or break. This has happened to me a couple of times, and in one case you couldn't see the fault in the filament. I think it would be worth changing the bulb, which would be much cheaper than changing the switch.
