hi lads and lasses
i have a mk 2 laguna estate and some horrible little git has knicked one of my headlight washer tops any dieas where i can get a new one from is it just the the cover or is there more to it ?
Hi Jasper1964 ... if your talking about the body coloured cover that clips on the spray head then I reckon is a dealer only part, or if your lucky you might find one in a breakers yard .... they do come off in carwashesthough, I've seen several (not sure which models) in our local Sainsburys carwash lying on the ground obviously pulled off when the brushes pass over the bumper (then again that carwash has a reputation of removing roof antenna, mirrors and rear spoilers as well ... .:crazy: )
Hope it helps :)
Tourerman
The Headlamp Washer Cover is not part of a new washer system so as Truckbusuk says try a breakers yard or one of the breakers on thi forum, you might be lucky and get the right colour.
Tourerman
