I have just purchased a twingo Dynamique on an 18 plate. Is it possible to fit heated seats to it. It was an option when I order my car but I didn***8217;t pick it. Now I wish I did. Will Renault fit them for me?
Captur 2017 1.5DCi EDC
It should be possible for Renault to do it but it won't be cheap. Some of the wiring may be there and you may even have blanks where the switches go but two Renault spec seats plus labour will be a few hundred quid at my guess.
and as its an 18 car and still very much under manufacturers warranty, it will have to be Renault that does it, or you will invalidate your whole warranty and you dont want to do that. but as TD says, it may be very expensive, the loom will be there, the blanking plugs for the switches will be there but the seats may not have heaters in and you will have to have them replaced. Not going to be Cheap:frown2:
  • Like
Reactions: twodogs
GRAND should just about cover it.. Could be more as might need a higher amp alternator..
