I have a Mark 3 Espace 2.2 DT.
The heater control bank on the drivers side has stopped working, the bottom three lights just flash on and off simultaneously but I cannot select a heater function.
The heater fan also is not working and the rear window heater has stopped, the passenger heater control has also stopped working.
Took it to Renault and their diagnostic machine did not show any faults, but I have waited nearly four weeks now for them to get their other computer system working and it is still out of action.
Any advice would be appreciated.
Many thanks
hi try this reset if its the same as my t reg
1.with the ignition off turn the temp to cold
and set the fan speed to zero
2.press and hold the top centre and bottom centre buttons
3.turn the ignition on when the light for the heat flashes
release the buttons
4 if all is ok the bottom right and heat light should be lit
5.if there is a problem the bottom centre and right will be lit
if there is a problem most are caused by a faulty resistor pack check my listings
http://www.renaultforums.co.uk/espace/11353-renault-espace-heating-cooling-heater-fan-not-working-fix-pics.html
http://www.renaultforums.co.uk/heating-cooling/22418-1999-espace-heater-resistor-pack-temporary-bypass.html
read this link very similar problems
http://www.renaultforums.co.uk/electronics/35248-heating-problems-creates-more-troubles-fixed.html
Problem Fixed
Many thanks to 'fixmycar'
Followed the instructions and problem sorted in seconds.
I am now waiting for the Renault dealer to catch up with me as they allowed me to take the car away without paying the bill for trying to find the fault.
