first hi to all
hi have got my self renult espace 2.1 td 94 l reg
now iv found out when i turn the fan it will not blow
any air from vents i can feel warm air when i put my hand on
the front vents when i moving just i do i need to replace
the motor or resistor pack as im unsure wot to do or is there any way i can to to see whitch oneneeds replacing
any help will do thanks gary
Tourerman
Hi Gary, welcome to the forums, have you checked the fuse? try that first.
hi davesss
iv looked in the glove box for the fuse 15amp seems fine
when i turn the switch it clicks or when taken out dos nothing is the a different fuse under bonet thanks gary
