Thanks so much to the both of you my front passenger window is now WORKING! :d
I came home from work last night and had a blast at fixing it before the rain started again. Thankfully the rain stayed off for a few hours and all is sorted.
Without this fantastic forum and great people like yourselves who take the time and energy to help people I would never have had a clue where to start!
For me the hardest part of the whole job is getting the actual door panel clipped back on where those big plastic clips join onto the metal parts. This is where I asked the wife for a helping hand and she was more than good. She more or less got them on herself lol.
When I took the panel off I could see Renault had actually disconnected the regulator from the main connection so it was never going to start working on its own again.
I used these pictures and instructions
http://sites.google.com/site/proluxelectronics/how-to
as well as great advice from HeatherJ and darokane. I could never have did it without you both.
My regualor was slightly different than HeatherJ's as it is a 2007 model so I also used these pitctures and instructions.
http://www.renaultforums.co.uk/showthread.php?t=81895&highlight=window+reset&page=6
All I did was take the regulator apart and spray the chip board with Maplin Electronic Solvent Cleaner. I couldnt actually take the chip board out so I just sprayed a lot inside and allowed it to drain off. I also sprayed the connectors and sealed around the inside of the lid as well as putting a large quantity of silicone sealent around the area where the foam sealent used to be. See the pictures in the last link above. I actually didnt even have a foam sealent!!! Perhaps Renault removed it when they had disconnected the main lead going to the regulator whilst I was waiting on the car going in for repair.
After I did this I also sprayed the main lead that goes to the regulator (Image 7 in the last link) with more of the Maplin Electronic Solvent and again covered that whole area with clear silicone sealant just as it is in the same picture.
I reconnected everything together after I had allowed the silicone sealant time to dry and put the panel back on. Now it was time to test it and to be honest I wasnt expecting a miracle but to my sheer surprise my window was working again!
At first the window fell about half way down and stuck again. The Wife panicked offcourse thinking we had a car sitting with an open window all night lol.
So I did as it says on the forum and turned the electrics on and off a few times until I got the window to the top. Then once it was up I held the switch in the up position for around 10 seconds to reset it, then let the window go to the bottom and held the switch down for around 10 seconds to reset it and then presto the window is working perfect again! The best part is now that the regulator is sealed properly this shouldnt happen again. Well to that window anyway! lol
Now for the back window. Anyone know if these are any easier? I know I need a torx 15 screwdriver for this one though.
Thanks again everyone for some superb help :d
