hi all
can some one please help my heater controls did not work
so i ad a look at the heater motor turns out to be a broken
wire so now works but only on high 1/2/3 wont work
but that would not be a problem but it comes on for about 15
seconds then gos off then back on iv checked thr resistor
on the right of heater blower wasnt sure if it worked so i attaced dome wire to it then to the battery it was spinning
would it be possable to connect the motor to the battery
so when i turn heater blower on it dont go off or is the some orther way round this i just want blower to stay on
and turn it of when not needed
thanks gary
Discussion Starter #2
resistor
can any one tell me is it possable to fix the resistor
by replacing it with a 20 amp fuse how do i di it
and is the resistor the green part in side the casing
thanks gary
