thought i'd better say hello.. as it seems i might be spending alot of time on here,, the gf's megane 2 has just started playing up,, and having searched the forums it seems like tdc sensor :crazy: , is there any other common faults that i should be looking out for?? the car has only covered about 25k,,,,,,,,
The Megane 2 seems to be pretty reliable in general,certaintly when compared to other Renault models.The VVT engines can give problems with de-phaser pulleys,and the French electrics can be a little temperamental,but all in all the Meg 2 is a good car.:)
What problems are you having at the moment?
cheers for the welcome
the engine dies after about 30 seconds on tick over,, but if i keep revved up for about 45 secs it seems to run ok until the engine is stopped,, then we get the same problems again of the engine cutting out
