:(hi all i am new to you site
i have recently bought a renault 19 16 valve
and i now have a problem with the gearbox it drives in 1st and second but is noisy really noisy it wont go in 3rd goes in 4th but again noisy but not as bad and it goes in 5th and is silent but jumps out when you let off the revs
does anyone know what is causing this and what i can do to fix it
thanks in advance
Hello & Welcome to the Forums Ren1916v.
I'm sure a more technical Member than I will be along to assist with your post shortly.
Ottoman
Hi and welcome to the forum this is sounding very like its going to be a gear box change from the breakers yard to me has this just happened or has this been like this for a while the problem with this car that most 19 1.9 16v have had a hard life do you know of this being the case
no its only just started i bought this for the reason that its had a good life and been looked after its just a bit frustrating.. lol
is there no one else that could shed light on this issue as i'm still having problems locating another box
thanks
