OK, megane 2004. Firstly, the passenger side window broke. Then my car like many others had a complete mental attack and it happens in extremely wet weather. Problem one, my wheel access is open and I need a replacement? Problem two the mechanics I used broke open the cover for the fuse box? So i also need one of these. Problem three, the fuse box itself is showing some corrosion, bluey bits? From my post you may surmise i know what im talking bout but i don't. Where can I source parts to make it water proof? and is the corrosion a problem?
