Can anyone please advise if head or cam from a 1997 2.2 non turbo leguna will fit the espace 2.2 td from the same year.
I have removed engine to replace clutch and do cam belts and water pump, whilst all stripped down thought i would change the rocker gasket which showed signs of leaking, I found the cam to be excesivly worn on the lobes and will need to replace it. I know where there is a lowish milage laguna from which i can get the either the head or if the same the camshaft and lifters ect.
Hope somene can help as without it i having to borrow a vehicle to tow with.
Yes it is esentially the same engine although the camshaft may have different timing as in valve duration and lift but it does fit i have used non turbo laguna engines as doners to fix turbo espace engines
