Help.
Dodgy number plate bulb, changed it, now all the right hand side lights, tail lights and number plate are not working. Has to be a fuse, but whre? Nothing obvious in the glovebox, teh engine fusebox just has half a dozen big fuses.
HELP!!!!!
What are you like, :grin2: Thought it was only me who did that.. :wink2:
Headlights working ok, can you check ALL lights on the car,, so I have a fighting chance of only making you check 1 fuse here
Sorted it.
It was a fuse. Fuse box was located just above right of the battery, in a black case with a red clip. You take the cover off and the fuse board is upside down! So you're looking at a plain plastic panel. I thought it was some sort of sealed ECU at first, but by lifting it up and twisting it, you get to the fuses. I knew it was most likely a 10amp, so went for the two next two each other, and one had blown.
