1 - 9 of 9 Posts
Hi Stuart - have you checked the air cleaner and does it run any better with it removed - don't be tempted to run the car for long periods with it out also check that all vacuum pipes are sound aand not cracked or broken. Is it firing on all cylinders.:)
hi it is firing all cylinders and i someone said about a temperature switch telling the engine to give the rong mixture i will chech the pipes for splits and cracks
Hi mate,
I've also 97 Clio RSI with 1783cc F3P engine.Mine was also working rich mixture until I renewed the engine airflow meter staying on the end of plastic pipe fitted to airbox(I've direct air filter).
I suggest you to check all the firing system.
1 - 9 of 9 Posts
