Hi new on the forum.
Bought a 2006 56 plate renault trafic dci 100 2 weeks ago with 60,000 miles,
Thought the van felt a bit slugglish from 2000rpm to 3000rpm then it pulls as normal,
Got a service on it last week and had a air mass error code so replaced that problem still there.
couple of days later got the wiggly line box on in limp mode so turned the van off and on and it went away.
Took the van to the garage the following day and had different error code 1815 pressure sensor so i replaced this and the solenoid but the problem is still there,
Also cleaned the egr valve was a bit sooty but seemed fine but no further forward.
Any help greatly appreciated.
