I have just use a tripod tool to remove the old oil filter on a Scenic 1.5 dCi (2006 model). At the end of the process an open end of a black pipe with a diameter of about 1cm came into view. The end had a plastic fitting which looked like it went into another hole. The pipe was clean and empty. One end of the pipe started somewhere well below the oli filter and when the oil filter was removed, the pipe was easily long enough to reach most parts of the alternator and I think normally runs between the oil filter and the engine.
Any idea what the pipe is or where it goes - I might have dislodged it with the tripod as I removed the old oilf filter.
The car appears to run okey (at least when stationary) but I haven't moved it yet.
