We´ve just replaced one piston and cylinder head and removed high pressure pump (changed the gear) for the P9X-701 engine (3.0d) and after we´ve but all back together started the anomality :rant: :
When You crank/start the engine first time for some period of time (15min) it starts for 3 sec and dies out. If you start it again pretty much immediatley it dies out as soon as it starts (1 sec) but it starts.
What we´ve done:
1) first we tought it was air in fuel system, cause as we´ve cranked it we could see air bubbles coming from the fuel return line from the block. We used hand pump and cranked it so many times and got rid of the air.
2) we´ve cheked the heater plugs. They´re ok.
3) cause its cold country that I live in (vebruary was pretty much -25) and in the fuel tank was summer disel we changed it to winter disel. Also drained the filter for water... benefit zero :|
Could somone suggest what to do/check next? Or what could be the problem???
Why the engine starts and dies out immediately?
Could it be the high pressure pump? Could it be a bolt that we made ourselves for the fuel line (hollow inside) only diffrence from the original bolt and the bolt we made is that we only drilled one horisontal hole instead of two?
thanks for advance
What we´ve done:
thanks for advance
