can anyone tell me about the locking pin for the crankshaft? what i would like to know is that once the pin as passed throu the hole in the engine block does the pin locates into a hole in the crank webbing and there fore stops the crank from turning feft or right or does the crank webbing just rests a flat against the pin stopping the crank from turning clockwise but still allowing it to turn anti clockwise?... if it does enter a hole should there be some slight left to right free play?.... Scenic 1.4 16v 02 plate.
