sometimes it starts sometimes it dont. battery fine, turns over, sometimes will start first turn of the key other times could take up to 15 - 20 times:steam:. when it dont i get towed 10 foot and start straght away!!!!
p.s not the immobiliser
any help will be very appreciated
dave
hi m8:) welcome to the forum. sounds like a Top Dead Centre sensor fault m8,very common and is usualy at fault 9 times out of 10.
you can try and clean the sensor, its worked for quite alot of pepole now and its quick and easy m8.
heres a great link, which scen1c posted its a scenic in the pics but the same applies to any modle engine ectslight diff
http://www.renaultforums.co.uk/how-articles/10062-top-dead-centre-replacement-pictures.html
good luck alex:)
hi , i tryed what you said and you are magic thanks m8 works perfect and noticed the temp gauge isnt reading as hot now
thanks for the quick responce:d
