:crazy:Hi i,m new to this a trying to get some help i drive a renualt clio 1,4 16V, but am having problems with the back wheel . it's making a noise and the hub is getting very hot on short runs is it major and is it gonna brake the bank
Thanks pat for your quick reply it;s a 53 plate ,do you think it's an easy fix as i had quite a few problems off lately i still have engine management light on which i thought was the ignition coils as it was miss fring , but seems not have replaced the bad one ???Welcome to the forum
Jack up the car and spin the wheel by hand
If it doesn't turn freely then I would suggest that you have a seized/sticky brake. If it turn relatively freely, listen for any noises from the wheel bearing. Neither of these should break the bank
you may get a more informed opinion, if you add the year of your car![]()
