It want start it tries. I have been told it is the fuel pump but not sure. help please
OKay mate I'll give it a try and thanksHi, welcome. I make the assumption your 1.4 is the same 1.4 they put in my Megane. Anyhow when you say tries do you mean it turns over but will just keep cranking but not fire? Is it temperature related? Works when cars cold, wont when hot or vice versa?
Had a similar issue with my Megane actually (appears to be quite common) and it was a dirty TDC sensor. On mine its bolted to the top of the gearbox bell housing. Two bolts hold it in place and it stick's through a hole in the gearbox. Its magnetic so gets covered in tiny metal fillings stopping it working. Yours could be a similar issue, for 20min worth of work its worth a try. won't cost anything to give it a clean.
I don't think its that as the person who had it before me said he was driving on the a62 and it gust cut out and gust crank over no fire so I don't no but I will try that sensorHi, welcome. I make the assumption your 1.4 is the same 1.4 they put in my Megane. Anyhow when you say tries do you mean it turns over but will just keep cranking but not fire? Is it temperature related? Works when cars cold, wont when hot or vice versa?
There ant no lose off power gust cut out and wouldent fire up againNot too sure about the loss of power, but for the sake of undoing two 10mm bolts its worth a clean. Others will be along soon who can help more.
I have taken the pump out cleand it put in a bucket off water and put a battery on it but it seams like it works so I don't no it confused meYou can check to see if the fuel pump is totally dead, by giving the plastic pipes a squeeze and seeing if they're under any pressure. They should be still pressurised after a cranking attempt.
Also could disconnect the fuel connector and put it into a glass jar/fuel can/etc and crank the engine. If fuel comes out, you know that its at least pumping fuel.
If the pump runs, even if really weakly, I'd expect it to at least start. Even so, you can get a good idea by the amount of fuel coming out.
Obviously be very careful with the fuel + spark risks when doing this as you are working with the fuel system.
Si.
Gust wounded if the fuel filter is blocked would that stop it form starting cuz it sounds like when I try and start it no fuel is going few or could it be the relayChecked the TDC sensor yet?
