Hello all,..
not sure if this is the right section..... i have a Laguna 1.9 dci late 2001, just had a New Turbo and inter-cooler fitted,and after 40ish miles a "orange "warning light came on (not engine management red light, but one next to it)and experianced loss of power due to no turbo(limp home mode)...switch engine off and re-start all back to normal then a mile or so its back on again, had it code read and the code said "induction" problem, fitted an airflow meter but still the same, any other ideas/tips on what to do next, after clearing codes it will come on again after a few miles.:steam:
Thanks in advance for any help you can give.
Sean19.
Thanks chris M, will have ago at cleaning the egr valve or probably might just renew it altogether.
Will report back on the result.... any more ideas any one ?
Thanks.
Double check all the vaccuum hoses are in place,especially the one that goes to the turbo boost solenoid and then to the turbo.
The solenoids themselves can give problems too.
What fault code number are you getting?
just been reading info on EGR valve and turbo failure threads for dci problems by doing a search on here, some great info and experiances posted, will get the mechs to D/check these hoses tomorrow and will ask them what the fault code was and post on here t/morrow, thanks lagdti.
