Hello and welcome to the forum iam sure the fuses for the wipers are inside the car but i may be wrong but if they are in the engine bay were you are working iam sure there will be some kind of clip so you can gain access to the fuse
Hello & Welcome to the Forums Idiot.
I'm not sure where the wiper fuse is on the Scenic II is there anything else not working as usually the fuses cover more than one item, I presume from the age of your car that it is still covered by warranty, I realise that you need wipers in this weather prior to a dealer visit.
There are some fuses to the lower right between the steering wheel & the drivers door, Also some are in the glove box behind a cover.
Ottoman
