I'm hoping that someone can help me, I recently put my 1996 Twingo through a Control technique in France (it is the same as the MOT but carried out by independant assessors that cannot do repairs on the vehicle). It failed on excessive CO emissions.
The readings where:
CO idle: 0.3 (needs to be 0.5 to pass)
CO acceleration: 0.36 (needs to be 0.3 to pass)
Lambda: 1.021 (needs to be 0.95 - 1.03 to pass)
For the repeat test I changed the spark plugs, air filter, oil filter, oil and put on a new exhaust silencer. I also used an additive like Red X to clean carbon deposits.
The car failed again but the results where worse.
The results where:
CO idle: 0.46 (so this has improved slightly)
CO acceleration: 0.46 (This is worse)
Lambda: 1.040 (This is worse)
Does anyone one have any advice on what I can do to try and get the car to pass without costing a fortune as at this stage I have to weigh up the cost of the repair to the value of the car.
The readings where:
The results where:
