:steam:
hi people you all seem very knowledgable i have a problem with my 2.0 16v megane in that when i start it up the revs shoot straight up to 5000rpm. any ideas would be greatly appreciated
Hi there madge1980 and a warm welcome to Renault Forums, I'm sure one of the tech guys will give advice soon, in the mean time if you do a search you may find something useful as I seem to remember a similar cry for help,
Regards Leroy
Welcome, do the revs drop at all? and if so after how long? I dont know what the issue is but the more info you can provide then the techies will be able to help.
hi sorry no the revs dont drop they start going higher if anything. i recently replaced 12 valves cos the cam belt snapped. maybe ive put it back together incorrectly as i didn't strip it! Thanks again.
I have a similar problem with revving, my megane seems to idle at 2000 when I've just started up.
I can usually cure it by turning it off and back on (solution to EEEVERYTHING! ) but only if I've driven it with an idle of 2000 for a few minutes. Any ideas?
thanks samross got it sorted now, the w**k**s who sold me the head gasket set gave me the wrong inlet manifold gasket, was sucking in too much air! selling it now though.
