Hi its a pre tenshed pully wheel if you fit a 13mm spanner on the small pully wheel nearest to you and pull it towards you you will be able to pull the belt off and again to put the new belt back on but watch your fingers because its a very strong spring.
Remmember to draw a little diagram of the belt before you take it off so as to help you when you putting it back on i hope this helps
