how do you check the transmission fluid on a espace 2.0 16v 2000 plate
G grantnnat · Registered Joined May 1, 2011 · 14 Posts Discussion Starter • #1 • May 5, 2011 how do you check the transmission fluid on a espace 2.0 16v 2000 plate
R Recycled Scenic · Guest Joined Jan 1, 1970 · 0 Posts #2 • May 5, 2011 Assuming its the JB5 gearbox you have? With the car on level ground there is a plastic plug with 2 lugs that unscrews from the front towards the bottom of the gear box which is where you fill the gearbox until the oil starts to run out.
Lagdti · Premium Member Joined Dec 10, 2005 · 40,429 Posts #3 • May 5, 2011 There is some info and a few pics here..... http://www.renaultforums.co.uk/showthread.php?t=25471
