1 - 12 of 12 Posts
RIP 31-12-2008
Great post Laggy, many thanks for the time and effort involved, and now for the rear ones :d
Regards Leroy
Serves you right for having a flash motor....:d:d:d
I've got rear discs on the rust bucket if thats any good.....I doubt they work,but then nothing else does on it and it won't go fast enough to need any brakes.:)
RIP 31-12-2008
No, I was just wondering about the wheel bearing situation
for I believe they are part of the disc, or am I wrong :rolleyes:
the bearings are part of the hub and sit in the hub carrier i.e. it is behind the disk and takes about 3.5 tonnes to of pressure to remove the bearing, normally has to be pushed out of the hub TOwards the engine / gearbox . To check, jack up the wheel and wiggle it on the 1/4 to 1/4 past (on the horizontal) if there is a large amount of free play then i would point to bearing but if unsure get it checked
Ev
THAY CALL THEM SEALED FOR LIFE?
Leroy,I know the wheel bearings need swapping over on rear discs on the Clios and 19's,but not 100% sure about your Lag.....
If they are then it's worth spending the extra money and buying new discs with a new wheel bearing and ABS ring already fitted.It is very easy to damage the bearings and the rings when swapping them over.......
1 - 12 of 12 Posts
