My sunroof has been leaking and has caused rather a large water stain by my passenger sun visor. Does anyone have any tips on how to clean/remove this stain.
I have found spray on Vanish and Oxy quite good at removing these type of stains.:)
You could try some of the valeting companies for advice
ello mate i have just had the same prob, leak from the sun roof, and i have also found a water leaking in to the passenger side panel and the seatbelt is wet as well, check it out. i ahve a megane coupe 1999, think its a comman problem.
to get rid off stain try and steam clean it is you have a stemer.
If its just water (i.e. no dirt) that's caused the marks, then you could try lightly dampening the whole visor with clean water, then gently drying with a hairdrier.
Paul:)
leak in side panel passenger side (seat belt totaly wet)
hello people i have a coupe 1999 T reg, i have a leak. first the water came from the sunroof panel control (dripping) then i notised that the setbelt passengerside was all wet and so was the passenger side panel at the back.
does any one have any ideas how to solve.
its reley peeeing off i like the car but starting to hate it slightly helllllpppp.:rant:
