1 - 11 of 11 Posts
Hi, I am trying to change my wheel, I have alloys on my clio, I can't find the wheel hub nut spanner, to take the hub cap off. can't even get to the wheel! says it should be in glove box? What does this look like, I cant find anything to fit and I am really stuck. No one around to ask thought I would try here. Thanks x
Look inside the boot it may be beside the jack and other stuff.:p
Just remembered where it will be - it will be where the last person left it
Thanks.
That would probably be the mechanic that put my new tyres on last week. :mad:
Can't find it anywhere, not sure what I am actually llooking for anyway.
RIP 31-12-2008
Is the hub cap attached by a bolt with 3 or 4 small holes in the top?
Hi Boo - what you are looking for is the key to remove the centre cap - it has T- shaped handle usually made from plastic - but you could also try using a pair of pointy nosed pliers and turn it anti-clockwise:)
Thanks so much for going to the trouble of finding a pic I am very grateful! Its def not in the car, must have gone at the garage last week. Am just glad I found out now and not at the side of the M25 in the pouring rain! x
RIP 31-12-2008
A pair of needle nose pliers does the job, had to use them on mine a couple of times
yeah likel eroy said, needle nose pliers work a treat on them. always help me when customers dont have them:p
1 - 11 of 11 Posts
