Firstly thankyou,
The engine idle speed, flucuates, 400-700 rpm, although the car drives ok, so me trying to be clever replaced all four coil packs, although the problem is still there, is this a problem or should i just leave it as a 'if it isnt broke dont fix it thing' i have heard that even when replacing coil packs you need to get the ecu reset as it still thinks it got a faulty one so does not re adjust to it ?
Any ideas welcome, and thanks for the time !
Morning Chris,
Didnt have the light on, but this TDC sensor seems to crop up all over this site, i will check that, (is the tdc a physical switch or does is work on a magnet type reed switch thing as people say it seems to gather chards of metal?)
My wife has a megane03 and she has the problem of a sometimes no starter, so im thinking this also could be the tdc.
Thanks again.
The revs are ok when the engine is cold
