Hi All,
I have just sorted out starting problems on a renault grand scenic.
Few questions - what is the correct idle speed of a scenic on start up?
What idle speed should there be when stopping? (The inital speed after taking foot of throttle)
What revs should the scenics power band be? (turbo)
Mine is 750rpm, 500 - 610rpm, 3800rpm.
these - bar the 750rpm idle from startup speed seem off so what components should i check to make sure the rpms are correct?
remember Murphy never sleeps
hi all the info you have given seems about right as its all controlled by the ecu . read your last post and you've done a lot of work to it.does it drive properly? normally.come back cheers
