I have a laguna estate 1999 with a valeo ignition barrel and quite often when i turn the key it won't start the engine just does nothing, instrument panel is lit but it wont turn that extra bit to start. Would the barrel be worn???
Regards,
Steve...
Hi It is possible the key is worn - I had a similar prob with a Ford - it may be worth trying to get a new key cut - if that don't work you may be able to get one in a scrapper assuming they have akey to suit.:)
Thanks mate, i suspected that but i have another key and its the same, may change entire lock set as its nearly the same price as a matching ignition lock.
Thanx
Hi Kolobos - It may be worth checking with a good locksmith as some ignition barrels can be repaired and made to fit the existing key:)
