Hi, I'm just wondering if its possible to swap ECU ,UCH and keys from one Renault Trafic to another.
Thanks for reading
Yes it is, have a look on tbay for ECU kit traggic, and you will see what you need to change..
BUT, some are nothing do with the IMMO in this context..
A lot depends on year and size of the engine.. ( Fuel pump on some needs the stop start solenoid changing )
Thanks a lot . Been looking for this answer everywhere. Made my life lot easier ***x1f44d;***x1f44d;.
Thanks for reading
As long as Same Engine & Suffix.
M9R780 & M9R786 Have different injector types, for instance.
  • Like
Reactions: ours2012
Are these injectors coded in then on these Tim..
Thought these were plug and pray.
Plug at top not coded, plug in the centre coded ..
It's not That. M9R 780 (2006 -2008) Are Piezo, High Voltage Injectors.
M9R 786 (2009 -2011) Like mine, Are Solenoid, High Current, Injectors. ECU Needs to match.
  • Like
Reactions: ours2012
