Hi! I have a problem with a Renault Clio Grande 1.2 W reg (2000). The problem is a likely fault with the immobiliser. I left the car for a couple of weeks and the car would not start. It is not the battery, this is charged up. The key is locking and unlocking the car. It just will not fire. There is no fuel getting through to the engine and it is not a problem with the fuel pump, there is no electric getting to the fuel pump for it to even work. We have tested this. I have read on forums that there is a code you can use to override the immobiliser (which is the most likely problem). I think I have worked out the code using the key information - however, I can not work out how to enter the code on my model of car. Does anyone know how to enter the code on this car? Many thanks in advance for any advice you can give!
