hi.
I've been told that the injection advance solenoid valve is faulty on my wifes 98 1.9Td scenic.
Can anyone tell me where to find it, & can i replace it myself ?
Also, anyone know where to get one cheap ?
regards
Great site by the way
regards
Hi Jester as far as I know it usually on the bottom of the fuel injection pump - on some models it can only be removed by taking the pump off the engine. Try contacting a diesel specialist and they may be able to advise. Their is also a solenoid on top of th epump which is the stop solenoid. As a matter of interest what is the problem with the car.
Definately a job for a diesel specialist...
I'd check to see if there is a Lucas Diesel Service Centre near you.My local one in Yeovil (Somerset) is excellent.They are very helpful,very knowledgeable and the quality of their work is second to none.:)
sorry for the delay. car is very lumpy when cold, glow plug light ? (yellow zig zag) comes on intermittently. fault taken from code apparently.
thanks
btw, thanks guys for replying. i'm afraid im not sure how to use this site so hope this gets to you.
