Hi guys
I bought a 1.5 dci 2004 Scenic few days ago. Shortly after I found the following problem
A 'injection fault' message comes up on the dashboard every time I press hard on throttle on 4th and 5th gear. It's accompanied by STOP message and loud beep. It disappears after a second or two and doesn't appear in any other scenario. I don't feel any power drop, stall or anything like that. Everything's fine on first 3 gears even if throttle is pressed to the floor. It's also fine on 4th and 5th if I press gently
Any ideas? I'll be seeing my mechanic during next few days but for now it concerns me a lot as you can imagine... it's the first day I have this Scenic that I discovered this. I'm anxious that it may cost me a fortune to fix it - injection in diesel doesn't sound like a 'cheap-to-fix' issue
Thanks in advance for any suggestions
