I have a clio mk3 1.5DCI 2006 i have changed the glow plugs and ran injection cleaner through system and I'm still getting injection fault but no codes coming up on diagnostic test , I've asked a diesel injection garage if they can recondition my injectors but they said they are electronic and can't be done , any views on this as would appreciate .
The "injection fault" is a generic message about a complaint the ECU has with any one of about 20 parameters it monitors - its NOT necessarily an indication to do ANYTHING to the actual injectors.
If the dash is moaning at you there WILL be a code to read on the computers - you need a Renault speaking scanner else whoever is looking will miss it as you already have experienced
After a bit more investigation under the bonnet i have found the fault one of my injector seals have failed to work so away i can go on my travels once again thanks LvR for your input
